[GRASS-dev] GSoC 2018 report week 03 - GRASS GIS module for Sentinel-2 cloud and shadow detection
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Jun  4 02:03:41 PDT 2018
Hi Roberta !
On 03/06/18 14:38, Roberta Fagandini wrote:
> Hi all!
> I'm Roberta Fagandini and I'm working on my GSoC project, a GRASS GIS
> module for Sentinel-2 cloud and shadow detection.
> This is my report for the third week of coding.
> *1) What did I complete this week?*
>   * Implemented some changes from dev feedback (e.g. r.univar instead of
>     r.stats.zonal)
>   * Tested the modified python script and fixed bugs
>   * Prepared the python script in order to start implementing the GUI
>   * Started implementing the GUI
>   * Made some changes to the code depending on the GUI requirements (add
>     controls and check on input, output and temporary file, etc.)
>   * Cleaned up the whole code
>   * Tested the GUI and fixed bugs
>   * Frequently added the basic version of the GUI to my
>     GitHub repository [0]
>   * Shared progress with the community
I'm sorry, I haven't had the time to test your module, yet. A few
recommendation, though, based on a quick read of the code. I assume that
the relevant file is i.sentinel.mask.
- I would recommend to immediately create a real complete module that
can be installed with g.extension. This means creating a directory with
the module as .py file, a .html manual page file, but which could be
empty at the beginning, and a Makefile (see existing scripts in the core
code or in addons for examples). Being able to install everything
directly from github with a simple g.extension call makes testing much
easier.
- I see that all the input bands are marked as required. Are they all
necessary to the calculations ? If yes, aren't all these bands always
from the same acquisition ? If yes, then maybe we can avoid parameter
inflation by either just asking for a prefix and then getting all bands
from that prefix (following standard sentinel naming), or provide the
MTD file and read the band names from there, or you could ask for a
group name and it would be up to the user to create the group before
launching the module.
- A small idea in terms of coding style: I personally think that code
should be as easily understandable as possible. For example: in the
formulas you use the f_bands[] list. Maybe you could make this into a
dictionary and so instead of reading f_bands[0], we would read
f_bands['blue'] making the formulas easier to follow.
- Please follow PEP8 style guide (see [1]). Amongst others, this means
limiting lines to 79 characters. So:
	- The general style used for gscript.*_command calls in Python scripts is
	gscript.run_command('v.dissolve',
			    input=tmp["centroid"],
			    column='value',
			    output=tmp["dissolve"],
			    overwrite=True,
			    quiet=True)
	i.e. each parameter on its own line. This make it easier to read
	and lines shorter.
	- The same for r.mapcalc calls: if necessary you can construct
	the individual rules over more than one line.
I'll try to find some time this week to test the module and maybe come
back with some more feedback on the coding.
Great job so far, though !
Moritz
[1] https://trac.osgeo.org/grass/wiki/Submitting/Python#Style
