[GRASS-dev] Testing the new ZSTD raster compression - was: Re: GRASS GIS raster files: LZW compression?
Markus Metz
markus.metz.giswork at gmail.com
Sat Jun 9 09:54:34 PDT 2018
On Sat, Jun 9, 2018 at 8:26 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> * Markus Neteler <neteler at osgeo.org> [2017-12-06 10:41:19 +0100]:
>> Hi,
>> (subject renamed for clarity, original thread:
>> part 1:
https://lists.osgeo.org/pipermail/grass-dev/2017-October/thread.html#86395
>> part 2:
>> https://lists.osgeo.org/pipermail/grass-dev/2017-December/086738.html
>> Welcome to GRASS GIS 7.5.svn (r71892)
>> GRASS 7.5.svn (latlong):~ >
>> export GRASS_COMPRESSOR=ZSTD
> I am building a docker image, based on trunk, for which I need to ensure
> that ZSTD is the default compressor.
> What is the way to pre-set this at the configuration step, before
> compiling, so as to avoid to take care about it later on by setting
> GRASS_COMPRESSOR?
ZSTD is already the default compressor if available, no further settings
needed.
Markus M
> Thanks for any kind of comments, Nikos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180609/2914ef3b/attachment-0001.html>
