[GRASS-dev] Testing the new ZSTD raster compression - was: Re: GRASS GIS raster files: LZW compression?
Nikos Alexandris
nik at nikosalexandris.net
Sun Jun 10 11:44:19 PDT 2018
Nikos:
>> I am building a docker image, based on trunk, for which I need to ensure
>> that ZSTD is the default compressor.
>> What is the way to pre-set this at the configuration step, before
>> compiling, so as to avoid to take care about it later on by setting
>> GRASS_COMPRESSOR?
Markus M:
>ZSTD is already the default compressor if available, no further settings
>needed.
Great!
However, descriptions of compressors in the raster indroduction for
trunk [0], are maybe confusing.
ZLIB
ZLIB's deflate is the default compression method for all raster maps.
and
ZSTD
... ZSTD is the recommended default compression method.
The same piece of text is used for `r.compress` [1].
[0] https://grass.osgeo.org/grass75/manuals/rasterintro.html
[1] https://grass.osgeo.org/grass75/manuals/r.compress.html
I realised this before commenting in #3499. Yet, I thought "default" is ZLIB, and "recommended default" (like: "dear user,
it's best if you set ZSTD as the default") is ZSTD.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180610/2b0dccb9/attachment-0001.sig>
