[GRASS-dev] compile 6S library in GRASS
Roberto Marzocchi
roberto.marzocchi at gmail.com
Wed Jun 27 04:49:52 PDT 2018
Ok. But the 6s.cpp source code is compiled only for the i.attcorr module
and do not create the sixs executable. It is correct?
Because I have already discussed with Roberta for the GsoC program and I
know she need the executable to run th python module.
R
Il giorno mer 27 giu 2018 alle ore 13:25 Yann Chemin <
dr.yann.chemin a gmail.com> ha scritto:
> 6s was rewritten by Cristo in C++
> The code was absorbed in i.atcorr around the beginning of the century.
> On Wed, Jun 27, 2018, 13:20 Roberta Fagandini <robifagandini a gmail.com>
> wrote:
>> Hi all!
>> I need to compile the 6S library in GRASS in order to install the python
>> library Py6S [0].
>> The source code of 6S (v 1.1) is written in Fortran and it seems to be
>> the same code used for i.atcorr but I can't see the Fortran source code
>> within the GRASS svn [1]. In fact, I can't find the 6S executable on my
>> disk even if I installed GRASS.
>> Thanks in advance!
>> Roberta
>> [0]
>> http://py6s.readthedocs.io/en/latest/installation.html#alternative-manual-installation
>> [1] https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr
>> grass-dev mailing list
>> grass-dev a lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180627/456bd17a/attachment-0001.html>
