[GRASS-dev] compile 6S library in GRASS
Markus Metz
markus.metz.giswork at gmail.com
Wed Jun 27 04:47:46 PDT 2018
Hi Roberta,
On Wed, Jun 27, 2018 at 1:20 PM, Roberta Fagandini <robifagandini at gmail.com>
wrote:
> Hi all!
> I need to compile the 6S library in GRASS in order to install the python
library Py6S [0].
do you really need Py6S? Can't you use i.atcorr instead?
Markus M
> The source code of 6S (v 1.1) is written in Fortran and it seems to be
the same code used for i.atcorr but I can't see the Fortran source code
within the GRASS svn [1]. In fact, I can't find the 6S executable on my
disk even if I installed GRASS.
> Thanks in advance!
> Roberta
> [0]
http://py6s.readthedocs.io/en/latest/installation.html#alternative-manual-installation
> [1] https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180627/075c554e/attachment.html>
