[GRASS-dev] compile 6S library in GRASS
Roberto Marzocchi
roberto.marzocchi at gmail.com
Wed Jun 27 04:54:28 PDT 2018
Il giorno mer 27 giu 2018 alle ore 13:47 Markus Metz <
markus.metz.giswork a gmail.com> ha scritto:
> Hi Roberta,
> On Wed, Jun 27, 2018 at 1:20 PM, Roberta Fagandini <
> robifagandini a gmail.com> wrote:
> > Hi all!
> > I need to compile the 6S library in GRASS in order to install the python
> library Py6S [0].
> do you really need Py6S? Can't you use i.atcorr instead?
She use Py6S to calculate imput for i.atcorr
R
> Markus M
> > The source code of 6S (v 1.1) is written in Fortran and it seems to be
> the same code used for i.atcorr but I can't see the Fortran source code
> within the GRASS svn [1]. In fact, I can't find the 6S executable on my
> disk even if I installed GRASS.
> > Thanks in advance!
> > Roberta
> > [0]
> http://py6s.readthedocs.io/en/latest/installation.html#alternative-manual-installation
> > [1] https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr
> > grass-dev mailing list
> > grass-dev a lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180627/0eff208b/attachment.html>
