[GRASS-dev] compile 6S library in GRASS
Roberta Fagandini
robifagandini at gmail.com
Wed Jun 27 05:16:42 PDT 2018
I'm trying to create an automatic procedure to retrieve all the input
parameters for the control file of i.atcorr.
I need py6S because I want to automatically read and compute AOT at 550nm
from an AERONET file.
2018-06-27 14:01 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
> On 27/06/18 13:54, Roberto Marzocchi wrote:
>> Il giorno mer 27 giu 2018 alle ore 13:47 Markus Metz <
>> markus.metz.giswork at gmail.com <mailto:markus.metz.giswork at gmail.com>> ha
>> scritto:
>> Hi Roberta,
>> On Wed, Jun 27, 2018 at 1:20 PM, Roberta Fagandini
>> <robifagandini at gmail.com <mailto:robifagandini at gmail.com>> wrote:
>> > Hi all!
>> > I need to compile the 6S library in GRASS in order to install the
>> python library Py6S [0].
>> do you really need Py6S? Can't you use i.atcorr instead?
>> She use Py6S to calculate imput for i.atcorr
> That seems a bit overkill: why use Py6S to then use i.atcorr ? What are
> you trying to get from Py6S ?
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180627/0f7a649f/attachment.html>
