[GRASS-dev] pygrass: how to use GridModule with a module that has a 'width' parameter
Moritz Lennert
mlennert at club.worldonline.be
Thu Mar 8 06:22:13 PST 2018
On 08/03/18 15:18, Vaclav Petras wrote:
> On Tue, Mar 6, 2018 at 8:59 AM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> Hi,
> I'm trying to run the i.zc module in parallel on several tiles. I
> use this syntax
> if options['tile_width']:
> parallel = True
> width = int(options['tile_width'])
> height = int(options['tile_height'])
> overlap = int(options['overlap'])
> processes = int(options['processes'])
> kwargs = {'input' : inputraster,
> 'output' : temp_edge_map,
> 'width' : int(options['zc_width']),
> 'threshold' : float(options['zc_threshold']),
> 'quiet' : True}
> if parallel:
> grd = GridModule('i.zc',
> width=width,
> height=height,
> overlap=overlap,
> processes=processes,
> split=False,
> **kwargs)
> However, this fails (understandably) with
> TypeError: type object got multiple values for keyword argument 'width'
> Is there a way to work around this name conflict ? Do I have to
> define my own class derived from GridModule to change the parameter
> names ?
> Try `width_` instead of `width` for the module parameter. This is how
> grass.script works (mostly to avoid conflicts with Python keywords
> namely lambda), but without checking the code, I don't know if PyGRASS
> has this implemented.
It doesn't. I tried width_ for both the i.zc parameter and the
GridModule parameter. Neither were accepted as valid parameters.
Moritz
