[GRASS-dev] pygrass: how to use GridModule with a module that has a 'width' parameter
Pietro
peter.zamb at gmail.com
Fri Mar 16 00:26:11 PDT 2018
Dear Moritz,
On Thu, Mar 8, 2018 at 3:22 PM, Moritz Lennert <mlennert at club.worldonline.be
> wrote:
> On 08/03/18 15:18, Vaclav Petras wrote:
> Try `width_` instead of `width` for the module parameter. This is how
>> grass.script works (mostly to avoid conflicts with Python keywords namely
>> lambda), but without checking the code, I don't know if PyGRASS has this
>> implemented.
> It doesn't. I tried width_ for both the i.zc parameter and the GridModule
> parameter. Neither were accepted as valid parameters.
I've modifiredt the Module class to support this in r72367 [0].
Let me know if fixed your problem,
all the best
Pietro
[0] https://trac.osgeo.org/grass/changeset/72367
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180316/15d231c1/attachment-0001.html>
