[GRASS-dev] GSoC Project
sharry gill
sharrygill5656 at gmail.com
Sat Mar 10 02:00:07 PST 2018
Hello,
Thanks for suggestions!
Here is the draft proposal with improvements: Link to proposal
<https://docs.google.com/document/d/1G3cAkTXh_DAGyG26Mi1Sw3Ot2IL1msReG-_KFTSp2Nc/edit?usp=sharing>
Thank You
Supreet Singh
https://singhsupreet.github.io/
On Sat, Mar 10, 2018 at 2:09 PM, Margherita Di Leo <diregola at gmail.com>
wrote:
> After designing the tool, you should spend some time and reconsider what
> you have written in the timeline, which currently says absolutely nothing
> about the actual implementation, as you use generic sentences about writing
> "the code" and compiling "the code".
> Please, take a look at former years student proposals to get a hint of how
> to structure a meaningful proposal, how to design your project and how to
> split up the project in milestones for your timeline.
> Thanks and regards,
> On Sat, 10 Mar 2018 at 09:21, Margherita Di Leo <diregola at gmail.com>
> wrote:
>> Hi,
>> I see that you have indicated in the first week: to design the tool,
>> actually you should be doing this now, as well as compiling the source
>> code, which you put in the bonding period. Rationale: how do you/we know
>> that you will be able to develop such tool if you haven't neither designed
>> it, nor compiled the source code and studied basic documentation.
>> Thanks
>> On Sat, 10 Mar 2018 at 07:10, sharry gill <sharrygill5656 at gmail.com>
>> wrote:
>>> Hi,
>>> Here is the draft proposal, I fixed it: Link To Proposal
>>> If any improvements are required, please let me know.
>>> Thank You
>>> Supreet Singh
>>> On Wed, Mar 7, 2018 at 9:49 PM, Luca Delucchi <lucadeluge at gmail.com>
>>> wrote:
>>>> On 7 March 2018 at 09:08, sharry gill <sharrygill5656 at gmail.com> wrote:
>>>> > Hello,
>>>> hi,
>>>> > May be this is poasible that, if we allow user only to select
>>>> modules, and
>>>> > flags will be automatic.
>>>> yes, so please improve your proposal..
>>>> ciao
>>>> Luca
>>>> www.lucadelu.org
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180310/a0eb6f18/attachment.html>
