[GRASS-dev] pygrass: how to use GridModule with a module that has a 'width' parameter
Moritz Lennert mlennert at club.worldonline.be
Sun Mar 18 13:24:01 PDT 2018
Le Sun, 18 Mar 2018 21:19:11 +0100,
Moritz Lennert <mlennert at club.worldonline.be> a écrit :
> Hi Pietro and greetings from the Bonn code sprint !
> Le Fri, 16 Mar 2018 08:26:11 +0100,
> Pietro <peter.zamb at gmail.com> a écrit :
> > Dear Moritz,
> > On Thu, Mar 8, 2018 at 3:22 PM, Moritz Lennert
> > > wrote:
> > > On 08/03/18 15:18, Vaclav Petras wrote:
> > > Try `width_` instead of `width` for the module parameter. This is
> > > how
> > >> grass.script works (mostly to avoid conflicts with Python
> > >> keywords namely lambda), but without checking the code, I don't
> > >> know if PyGRASS has this implemented.
> > > It doesn't. I tried width_ for both the i.zc parameter and the
> > > GridModule parameter. Neither were accepted as valid
> > > parameters.
> > I've modifiredt the Module class to support this in r72367 [0].
> > Let me know if fixed your problem,
> > [0] https://trac.osgeo.org/grass/changeset/72367
> Yes, this fixes my problem. Thanks a lot !
Maybe a candidate for backport to 7.4 ?
Moritz
