[GRASS-dev] pygrass: how to use GridModule with a module that has a 'width' parameter
Markus Neteler
neteler at osgeo.org
Fri Mar 23 15:25:06 PDT 2018
On Sun, Mar 18, 2018 at 9:24 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> Le Sun, 18 Mar 2018 21:19:11 +0100,
> Moritz Lennert <mlennert at club.worldonline.be> a écrit :
>> Hi Pietro and greetings from the Bonn code sprint !
>> Le Fri, 16 Mar 2018 08:26:11 +0100,
>> Pietro <peter.zamb at gmail.com> a écrit :
>> > Dear Moritz,
>> > On Thu, Mar 8, 2018 at 3:22 PM, Moritz Lennert
>> > > wrote:
>> > > On 08/03/18 15:18, Vaclav Petras wrote:
>> > > Try `width_` instead of `width` for the module parameter. This is
>> > > how
>> > >> grass.script works (mostly to avoid conflicts with Python
>> > >> keywords namely lambda), but without checking the code, I don't
>> > >> know if PyGRASS has this implemented.
>> > > It doesn't. I tried width_ for both the i.zc parameter and the
>> > > GridModule parameter. Neither were accepted as valid
>> > > parameters.
>> > I've modifiredt the Module class to support this in r72367 [0].
>> > Let me know if fixed your problem,
>> > [0] https://trac.osgeo.org/grass/changeset/72367
>> Yes, this fixes my problem. Thanks a lot !
> Maybe a candidate for backport to 7.4 ?
For the (list) record, it has been done recently.
Markus
