[GRASS-dev] Use 'from=' parameter in python script
Nikos Alexandris
nik at nikosalexandris.net
Thu Mar 22 02:36:05 PDT 2018
[all deleted]
In the same script,
import grass.script as g
from grass.gunittest.case import TestCase
and
rescale_output = g.read_command('r.rescale', overwrite=True, verbose=True,
input=band, output=output_map_name, to=to_range)
print rescale_output
cls.runModule('r.rescale', overwrite=True, verbose=True,
the former will print the output of `r.rescale`, the latter will not.
Is there a way to get the output of `runModule`, while building a test suite?
And avoid using a `grass.script` function?
Is the purpose of `expecting_stdout=False` in `runModule()` to test if a
module emits something to stdout? [0]
Thanks, Nikos
[0] https://grass.osgeo.org/grass74/manuals/libpython/_modules/gunittest/case.html#TestCase.runModule.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180322/44d1de7f/attachment.sig>
