[GRASS-dev] Python Unit-test On "r.basins.fill"
Sunveer Singh
singhsunveer54 at gmail.com
Sat Mar 24 08:48:02 PDT 2018
Let's, start with v.to.db, I attached the test for it.
if any improvements are needed, please let me know.
Thank You
Sunveer
https://sunveersingh.github.io/
On Sat, Mar 24, 2018 at 5:19 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Sunveer,
> It's great to have you back!! Thanks much for your contributions and
> enthusiasm!
> Here are some modules that are lacking tests:
> * v.to.db
> * v.to.rast
> * v.support
> * r.what
> * several r.out.* modules
> * i.pca
> Cheers from the code sprint in Bonn :)
> Vero
> 2018-03-24 10:08 GMT+01:00 Sunveer Singh <singhsunveer54 at gmail.com>:
>> Thanks a lot.
>> Now on which module should I write test?
>> Thank You
>> Sunveer
>> On Sat, 24 Mar 2018, 14:37 Luca Delucchi, <lucadeluge at gmail.com> wrote:
>>> On 24 March 2018 at 03:33, Sunveer Singh <singhsunveer54 at gmail.com>
>>> wrote:
>>> > Hi,
>>> Hi Sunveer,
>>> > Thanks for the feedback, I have attached the complete working test,
>>> run on
>>> > nc_basic_spm_grass7
>>> thanks a lot, submitted in r72546.
>>> https://trac.osgeo.org/grass/changeset/72546
>>> > Thank You
>>> > Sunveer
>>> ciao
>>> Luca
>>> www.lucadelu.org
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180324/675cf1cb/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180324/675cf1cb/attachment-0001.py>
