[GRASS-dev] Python Unit-test On "r.basins.fill"
Luca Delucchi
lucadeluge at gmail.com
Sat Mar 24 17:29:34 PDT 2018
On 24 March 2018 at 16:48, Sunveer Singh <singhsunveer54 at gmail.com> wrote:
> Hi,
Hi Sunveer,
> Let's, start with v.to.db, I attached the test for it.
> if any improvements are needed, please let me know.
I'm sorry but you should change something.
In setUpClass you should copy the geology map because I run the script
in user1 mapset and it failed.
In tearDownClass you should remove the created map.
> Thank You
> Sunveer
> https://sunveersingh.github.io/
ciao
Luca
www.lucadelu.org
