[GRASS-dev] Python Unit-test On "r.basins.fill"
Sunveer Singh
singhsunveer54 at gmail.com
Sat Mar 24 21:56:13 PDT 2018
Done, attached the working file!
Thank You
Sunveer
https://sunveersingh.github.io/
On Sun, Mar 25, 2018 at 5:59 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 24 March 2018 at 16:48, Sunveer Singh <singhsunveer54 at gmail.com> wrote:
> > Hi,
> Hi Sunveer,
> > Let's, start with v.to.db, I attached the test for it.
> > if any improvements are needed, please let me know.
> I'm sorry but you should change something.
> In setUpClass you should copy the geology map because I run the script
> in user1 mapset and it failed.
> In tearDownClass you should remove the created map.
> > Thank You
> > Sunveer
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180325/c453b2a7/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180325/c453b2a7/attachment-0001.py>
