[GRASS-dev] any randomness in i.segment ?
Moritz Lennert
mlennert at club.worldonline.be
Wed Mar 28 10:51:01 PDT 2018
On 28/03/18 17:53, Markus Metz wrote:
> On Wed, Mar 28, 2018 at 3:04 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> > Hi,
> > Working with a colleague and comparing results we were wondering
> whether i.segment contains any randomness effects which might make
> results differ from one run to another.
> There is no randomness in i.segments. Given he same input data and
> settings, results should be identical between runs, i.e. repeatable.
> Did you do a simple diff with r.mapcalc?
No, but we have variance and spatial autocorrelation values for the
datasets and didn't get the same results. As there is no randomness, I
suppose my colleague did not define the region the same way I did.
Unfortunately, he only kept the numerical values, not the segmentation
results.
> > In the manual it says in section Seeds in the chapter on region growing:
> > "The seeds map can be used to provide either seed pixels (random or
> selected points from which to start the segmentation process) or seed
> segments."
> > which sounds as if the module creates random seeds if none are given.
> Looking through the code, I do not find such creation of random seeds,
> though. Is this just me not looking correctly, or aren't there any ?
> A seed map can be created by randomly selecting pixels, e.g. with
> r.random. If a seed map is not given, all non-NULL cells are seeds.
Thanks for the info.
Moritz
