[GRASS-dev] [GRASS GIS] #3502: v.proj location not set in dialog
trac at osgeo.org
Fri Mar 30 11:25:29 PDT 2018
Reporter: balagates | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.4
Component: wxGUI | Version: 7.4.0
Resolution: | Keywords: v.proj location
CPU: OSX/Intel | Platform: MacOSX
Comment (by balagates):
I believe I found what caused this change. In
./gui/wxpython/gui_core/forms.py 7.2.2 (71322) vs 7.4.0 (71217)
elif prompt == 'location':
win =
gselect.LocationSelect(parent=which_panel,
value=value)
win.Bind(wx.EVT_COMBOBOX,
self.OnUpdateSelection)
win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
changed to
win =
value=value)
win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
win.Bind(wx.EVT_TEXT, self.OnSetValue)
There were a large number of other changes that appear unimportant for
this. I do not understand why the 7.2.2 is a higher revision than the
7.4.0 but it must be due to different branches.
I am not confident enough to make a change to the source. Is there some
other case where the change made sense? Which branch is the right one to
make the change in?
After changing to EVT_COMBOBOX the selection from the pulldown list
appears to work as I expect but then typing in the location no longer
appears to work. In my use the former seems more important but there
might be cases where the later is more important.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3502#comment:2>
