[GRASS-dev] [GRASS GIS] #3537: Add functionalities –tmp-location and –no-clean
GRASS GIS trac at osgeo.org
Sat Mar 31 09:00:45 PDT 2018
  Reporter:  radeknovotny94  |      Owner:  grass-dev@…
      Type:  enhancement     |     Status:  new
  Priority:  normal          |  Milestone:  7.6.0
 Component:  Startup         |    Version:  svn-trunk
Resolution:                  |   Keywords:  tmp-location, no-clean, exec
       CPU:  All             |   Platform:  All
Comment (by radeknovotny94):
 Replying to [comment:1 wenzeslaus]:
 > Thumbs up for creating a `find_tmp()` function, but you replaced\\
 > Note esp. the for loop and the test using try.
 I looked at it again and I think that finally is all new function
 {{{find_tmp}}} unnecessary. Because it is set environmental variable
 TMPDIR at the end of function {{{create_tmp}}}.
 # promoting the variable even if it was not defined before
 os.environ['TMPDIR'] = tmpdir
 It means that TMPDIR have to be defined when we call function for creating
 temporary location.
 gisdbase = os.getenv('TMPDIR')
Ticket URL: <https://trac.osgeo.org/grass/ticket/3537#comment:3>
