[GRASS-dev] GSoC introduction Roberta Fagandini
Moritz Lennert
mlennert at club.worldonline.be
Thu May 3 05:03:37 PDT 2018
Hi Roberta,
On 25/04/18 18:03, Roberta Fagandini wrote:
> 2018-04-25 16:03 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>:
> Looking at your bash scripts, I think the first thing to do during
> this bonding period is, as you planned yourself, to get familiar
> with the writing of GRASS modules in Python. You can have a look at
> existing scripts [1, 2] to get feeling for this works and how to
> structure addon code in order to make it directly installable with
> g.extension.
> You can find the actual function definitions and documentation of
> the GRASS Python scripting library at [3]. The functions in that
> library should be more than enough to translate your scripts into a
> (or several) modules.
> Be aware that GRASS modules create their own GUI. So, unless you
> need some interactive features in your modules, you will not have to
> program your own GUI.
> Thank you for your precious suggestions! I'll start studying how to
> write a GRASS module in Python in the next days and at the same time I
> will keep on testing the procedures so as to show you some results and
> fix some open points.
> Something else you should probably do during this bonding time is to
> elaborate a schema of your algorithm, so that it is easier to
> understand what it does at each step.
> Yes, this could be very useful also for me in order to better organize
> and put in order everything!
Have you advanced on any of this ? Do you have any questions ? Please
don't hesitate to ask on the mailing list.
Best wishes,
Moritz
