[GRASS-dev] [GRASS GIS] #3223: r.info displays wrong timestamp after t.rast.series with a where clause
trac at osgeo.org
Wed May 9 00:01:58 PDT 2018
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.4.1
Component: Default | Version: svn-trunk
Resolution: fixed | Keywords: r.info
CPU: Unspecified | Platform: Linux
Changes (by veroandreo):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 neteler]:
> Please close the ticket if issue is solved.
I had left it open because there's an open question (see comment 3).
However, since the issue is fixed, I close it now. Re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223#comment:6>
