[GRASS-dev] [GRASS-SVN] r72686 - grass/trunk/raster/r.mode/testsuite
Anna Petrášová
kratochanna at gmail.com
Fri May 4 20:57:37 PDT 2018
I just wanted to point out, that some of the newly added tests were
actually not testing anything (see below) or failing because of
whitespace, please be more careful what you commit.
Thank you,
Anna
On Fri, May 4, 2018 at 11:47 PM, <svn_grass at osgeo.org> wrote:
> Author: annakrat
> Date: 2018-05-04 20:47:30 -0700 (Fri, 04 May 2018)
> New Revision: 72686
> Modified:
> grass/trunk/raster/r.mode/testsuite/testrmode.py
> Log:
> r.mode: fix nonsense testsuite
> Modified: grass/trunk/raster/r.mode/testsuite/testrmode.py
> --- grass/trunk/raster/r.mode/testsuite/testrmode.py 2018-05-05 03:32:36 UTC (rev 72685)
> +++ grass/trunk/raster/r.mode/testsuite/testrmode.py 2018-05-05 03:47:30 UTC (rev 72686)
> @@ -1,7 +1,7 @@
> Purpose: Tests r.mode and its flags/options.
> Author: Supreet Singh
> Copyright: (C) 2018 by Supreet Singh and the GRASS Development Team
> Licence: This program is free software under the GNU General Public
> @@ -13,10 +13,11 @@
> from grass.gunittest.case import TestCase
> from grass.gunittest.main import test
> class Testrmode(TestCase):
> - output='rmode'
> - base='geology'
> - cover='soils'
> + output = 'rmode'
> + base = 'geology'
> + cover = 'soils'
> @classmethod
> def setUpClass(cls):
> @@ -31,23 +32,10 @@
> self.runModule('g.remove', type='raster', flags='f', name=self.output)
> def test_1(self):
> - soilsID='soils'
> self.assertModule('r.mode', base=self.base, cover=self.cover, output=self.output)
> - self.assertRasterMinMax(map=soilsID, refmin=18683, refmax=46555,
> - msg="soilsID in degrees must be between 18683 and 46555")
> + self.assertRasterMinMax(map=self.output, refmin=21513, refmax=46487,
> + msg="soils must be between 21513 and 46487")
> - def test_2(self):
> - lakes='lakes'
> - self.assertModule('r.mode', base=self.base, cover=self.cover, output=self.output)
> - self.assertRasterMinMax(map=lakes, refmin=34300, refmax=43600,
> - msg="lakes in degrees must be between 34300 and 43600")
> - def test_3(self):
> - elevation='elevation'
> - self.assertRasterMinMax(map=elevation, refmin=2, refmax=4,
> - msg="elevation in degrees must be between NULL and NULL")
> if __name__ == '__main__':
> test()
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-commit
