[GRASS-dev] Difficulty compiling GRASS on Mac
Seth Price seth at planet.com
Thu May 10 12:09:43 PDT 2018
Hey all, I'm trying to compile GRASS on Mac 10.13.4 so I can compile and
link to the GRASS libraries. I don't need most of the GIS features, just
enough to create and run my own C++ modules. I'm having some troubles with
grass-7.4.0 and grass-7.4.1RC1. The first problem I'm having is an error
linking libgrass_gis.7.4.1RC1.dylib. I get this error:
Undefined symbols for architecture x86_64:
  "_libiconv", referenced from:
      _print_escaped_for_xml in parser_interface.o
  "_libiconv_close", referenced from:
  "_libiconv_open", referenced from:
ld: symbol(s) not found for architecture x86_64
I can rerun the command and manually add the correct linking path for
iconv, and it works. I'm not sure why it wouldn't find iconv otherwise, but
it is what it is. This is the initial configure command that I'm using:
./configure --with-opengl=aqua --with-prefix=/usr/local --enable-shared
I've found that I can change the configure command and fix that problem:
./configure --with-opengl=aqua --with-libs=/usr/local/lib
However, then it progresses and returns this error while compiling many
modules:
dyld: Library not loaded:
/usr/local/grass-7.4.1RC1/lib/libgrass_gis.7.4.1RC1.dylib
  Referenced from:
/usr/local/grass/grass-7.4.1RC1/dist.x86_64-apple-darwin17.5.0/bin/g.parser
  Reason: image not found
make: *** [d.correlate.tmp.html] Error 1
The dylib looks like it's been successfully compiled at
dist.x86_64-apple-darwin17.5.0/lib/libgrass_gis.7.4.1RC1.dylib and just the
linking path for the libraries is wrong. I can't seem to shake it with any
of the online GRASS compiling instructions I've found. What might cause
this? Are there any current instructions for getting the shared libraries
compiled and installed?
Also, I'm able to install via homebrew, but then I have this problem when
compiling my modules against GRASS:
*sources/CameraOptic.cpp:33:23: **error: **use of undeclared identifier
'PACKAGE'*
    G_verbose_message(_("(%5d) Camera optical adjustment..."),
*/usr/local/opt/grass7/grass-base/include/grass/glocale.h:10:26: note:
*expanded
from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
I've never seen it before and can only guess that it would be fixed by a
fresh install of GRASS from source. Identical code compiles fine under
Ubuntu. Does anyone know what might be causing this? Or what might I do to
fix it?
Thanks,
Seth
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180510/a0ff4317/attachment.html>
