[GRASS-dev] Difficulty compiling GRASS on Mac
Michael Barton
Michael.Barton at asu.edu
Fri May 11 12:51:21 PDT 2018
Eric Hutton at the Community Surface Dynamics Modeling System has created a recipe for compiling GRASS using Anaconda. You can find it at:
https://github.com/csdms-stack/grass-recipe
I'm using a variant of this to create the stand-alone binaries for the Mac.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On 5/11/18, 2:55 AM, "grass-dev on behalf of grass-dev-request at lists.osgeo.org" <grass-dev-bounces at lists.osgeo.org on behalf of grass-dev-request at lists.osgeo.org> wrote:
Date: Thu, 10 May 2018 12:09:43 -0700
To: grass-dev at lists.osgeo.org
Subject: [GRASS-dev] Difficulty compiling GRASS on Mac
Message-ID:
<CAD69hT5=ucACX1f075a39=6yC2=wg0vp5uLnkELEZ3bpJJhzSA at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hey all, I'm trying to compile GRASS on Mac 10.13.4 so I can compile and
link to the GRASS libraries. I don't need most of the GIS features, just
enough to create and run my own C++ modules. I'm having some troubles with
grass-7.4.0 and grass-7.4.1RC1. The first problem I'm having is an error
linking libgrass_gis.7.4.1RC1.dylib. I get this error:
Undefined symbols for architecture x86_64:
"_libiconv", referenced from:
_print_escaped_for_xml in parser_interface.o
"_libiconv_close", referenced from:
"_libiconv_open", referenced from:
ld: symbol(s) not found for architecture x86_64
I can rerun the command and manually add the correct linking path for
iconv, and it works. I'm not sure why it wouldn't find iconv otherwise, but
it is what it is. This is the initial configure command that I'm using:
./configure --with-opengl=aqua --with-prefix=/usr/local --enable-shared
I've found that I can change the configure command and fix that problem:
./configure --with-opengl=aqua --with-libs=/usr/local/lib
However, then it progresses and returns this error while compiling many
modules:
dyld: Library not loaded:
/usr/local/grass-7.4.1RC1/lib/libgrass_gis.7.4.1RC1.dylib
Referenced from:
/usr/local/grass/grass-7.4.1RC1/dist.x86_64-apple-darwin17.5.0/bin/g.parser
Reason: image not found
make: *** [d.correlate.tmp.html] Error 1
The dylib looks like it's been successfully compiled at
dist.x86_64-apple-darwin17.5.0/lib/libgrass_gis.7.4.1RC1.dylib and just the
linking path for the libraries is wrong. I can't seem to shake it with any
of the online GRASS compiling instructions I've found. What might cause
this? Are there any current instructions for getting the shared libraries
compiled and installed?
Also, I'm able to install via homebrew, but then I have this problem when
compiling my modules against GRASS:
*sources/CameraOptic.cpp:33:23: **error: **use of undeclared identifier
'PACKAGE'*
G_verbose_message(_("(%5d) Camera optical adjustment..."),
*/usr/local/opt/grass7/grass-base/include/grass/glocale.h:10:26: note:
*expanded
from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
I've never seen it before and can only guess that it would be fixed by a
fresh install of GRASS from source. Identical code compiles fine under
Ubuntu. Does anyone know what might be causing this? Or what might I do to
fix it?
Thanks,
Seth
