[GRASS-dev] GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Roberta Fagandini
robifagandini at gmail.com
Mon May 21 06:19:25 PDT 2018
Ciao Stefan!
2018-05-20 21:44 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath at nina.no>:
> Ciao Roberta,
> Thanks for the comprehensive report!
> One general hint: Even if the drawback is complex expression(s) I would
> suggest merging r.mapcalc calls. That can improve performance quite a bit
> (less data read and written) and reduces the need to manage temporary data.
> See also: https://grass.osgeo.org/
> <https://grass.osgeo.org/grass74/manuals/r.mapcalc.html#multiple-computations>
> grass74
> If you don't need the first_... To fifth_... files later, I would even say
> everything in 3rd_procedure.py until r.to.vect could be solved in a single
> mapcalc operation...
Thank you so much for your hints! I'm trying to clean up the code without
creating a too complex expression..I hope to share the new version by this
evening or tomorrow at the latest.
> Kind regards and again thank for your GSoC work,
> Stefan
Thanks again!!
Roberta
> *From:* grass-dev <grass-dev-bounces at lists.osgeo.org> on behalf of
> Roberta Fagandini <robifagandini at gmail.com>
> *Sent:* Sunday, May 20, 2018 4:33:57 PM
> *To:* soc at lists.osgeo.org; GRASS developers list
> *Subject:* [GRASS-dev] GSoC 2018 report week 01 - GRASS GIS module for
> Hi all!
> I'm Roberta Fagandini and I'm working on my GSoC project, a GRASS GIS
> module for Sentinel-2 cloud and shadow detection.
> This is my report for the first week of coding.
> Since my progress has been a bit faster than expected I have already
> discussed with my mentors about further additions to the project. Therefore
> I have already updated my wiki page [0] changing the timeline. In this way,
> I will be able to release a more complete module.
> *1) What did I complete this week?*
> - Checked the prototype version of the algorithm for cloud and shadow
> detection
> - Tested it
> - I better studied the documentation of the GRASS Python Scripting
> Library and started coding the GRASS python script following the
> workflow schema prepared during the bonding period [1]
> - Coded the 'data preparation' phase
> - Coded the clouds detection procedure
> - Added this first part of python script to my GitHub repository [2]
> - Discussed with my mentors about further additions
> - Discussed with the community about testing phase. I received some
> feedback and some developers stepped forward to help me in testing the
> algorithm
> - Shared progress with the community
> Unfortunately, I wasn't able to code on Thursday because of a PhD meeting
> with my supervisor.
> *2) What am I going to achieve for next week?*
> - Finish the translation of the algorithm in a basic python script
> adding the shadows detection procedure and the steps for checking and
> cleaning the final outputs (see [1] for details)
> - Improve the python script so as to have a "light" working python
> script (manage temporary file, clean up the code, etc.)
> - Test it and fix bugs
> - Start implementing the GUI
> *3) Is there any blocking issue?*
> No at the moment.
> Best wishes,
> Roberta
> [0] https://trac.osgeo.org/grass/wiki/GSoC/2018/CloudsAndShadowsDetection
> [1] https://drive.google.com/file/d/1KYEKvNBurBFHw1xUTLjM0PW
> 80Z-7br81/view?usp=sharing
> [2] https://github.com/RobiFag/GRASS_clouds_and_shadows
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180521/e26b4876/attachment.html>
