[GRASS-dev] GSoC Week 2 Report - Full support of Python 3 in GRASS GIS
Sanjeet edu.sanjeet at gmail.com
Sun May 27 12:10:37 PDT 2018
On Sun, May 27, 2018 at 12:57 PM, Sanjeet <edu.sanjeet at gmail.com> wrote:
> Hi everyone,
> This is my Week 2 report for the project "Full support of Python 3 in GRASS GIS"
> 1) What did I complete this week?
>     Updated the encode and decode function in utils.py to accept the
> encoding type
>     Ported functions from 'Script' library to deal with unicode/bytes
> (https://gist.github.com/sanjeetbhatti/6714dff40b8a0a6d30df25ce9e4faa20)
>     Tested the changes by running tests (testsuites)
>     Tested against the python-grass-addon scripts available from here
> (https://github.com/wenzeslaus/python-grass-addon)
> 2) What am I going to achieve for next week?
>     Write more tests for script library to test the changes
>     Look into the issue of running scripts for Python 3.5 and Python
> 3.6 (some tests fail on either of the versions)
>     Port other small libraries and scripts
> 3) Is there any blocking issue?
>     Not at the moment.
These are my links to wiki and public repository.
https://trac.osgeo.org/grass/wiki/GSoC/2018/FullSupportPython3#Week2
https://github.com/sanjeetbhatti/FullSupportPython3
Sanjeet Bhatti
