[GRASS-dev] [GRASS GIS] #3567: v.select: doubtful result with the default overlap operator selecting areas with lines
trac at osgeo.org
Mon May 28 05:33:35 PDT 2018
with lines
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.2
Component: Vector | Version: svn-trunk
Keywords: v.select overlap | CPU: Unspecified
Platform: Unspecified |
Trying to select areas with lines, I get a result using the overlap
operator that I don't really understand, and which I suspect being a bug.
Using the following command in the attached location, test_vselect mapset:
v.select ain=test_polys bin=test_line atype=area btype=line
out=result_overlap op=overlap
I get a result of only three areas selected (see attached map) where,
IMHO, all 41 should be.
I'll try to diagnose this further when I have the time...
The attached location includes the results of runs with op=intersects,
op=crosses and op=overlaps which provide the results I expect.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567>
