[GRASS-dev] [GRASS GIS] #3567: v.select: doubtful result with the default overlap operator selecting areas with lines
GRASS GIS trac at osgeo.org
Mon May 28 12:52:31 PDT 2018
with lines
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.4.2
 Component:  Vector       |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:  v.select overlap
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 In [changeset:"72747" 72747]:
 #!CommitTicketReference repository="" revision="72747"
 Vlib: fix with_z = 0 for Vect_line_check_intersection2() and
 Vect_line_intersection2(), fixes #3567 (backport trunk r72746)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:2>
