[GRASS-dev] [GRASS GIS] #3567: v.select: doubtful result with the default overlap operator selecting areas with lines
trac at osgeo.org
Mon May 28 14:12:32 PDT 2018
with lines
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.4.2
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.select overlap
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3567 mlennert]:
> Trying to select areas with lines, I get a result using the overlap
operator that I don't really understand, and which I suspect being a bug.
> Using the following command in the attached location, test_vselect
mapset:
> v.select ain=test_polys bin=test_line atype=area btype=line
out=result_overlap op=overlap
> I get a result of only three areas selected (see attached map) where,
IMHO, all 41 should be.
The problem was not the overlap operator of v.select, but instead that the
vector test_line is 3D, and one of the underlying library functions did
not ignore z as it should have done. This bug has been fixed in trunk and
relbr74 with r72746,7.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:3>
