[GRASS-dev] v.kernel: should the module take into account the resolution for default output ?
Markus Metz
markus.metz.giswork at gmail.com
Tue May 29 09:08:30 PDT 2018
On Tue, May 29, 2018 at 3:48 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Le Tue, 29 May 2018 15:19:39 +0200,
> Markus Metz <markus.metz.giswork at gmail.com> a écrit :
> > On Tue, May 29, 2018 at 2:21 PM, Moritz Lennert <
> > > Le Tue, 29 May 2018 08:59:47 +0200,
> > > > On Mon, May 28, 2018 at 6:16 PM, Moritz Lennert <
> > > > > Hi,
> > > > > AFAIU kernel density calculations, one takes a number of points
> > > > > and
> > > > redistributes this total number across the entire region using a
> > > > specified kernel function as estimator as to the spatial pattern
> > > > of this redistribution. The total sum should correspond to the
> > > > total number of points in the input. Is this understanding
> > > > correct ?
> > > > > In v.kernel, this seems to be dependent on the resolution:
> > > > > echo "4.5,4.5" | v.in.ascii in=- sep=comma out=testpoint
> > > > > g.region n=9 s=0 w=0 e=9 res=1
> > > > > v.kernel in=testpoint out=testrast radius=5 kernel=gaussian --o
> > > > > r.univar testrast
> > > > > sum: 0.999544365566944
> > > > > but
> > > > > g.region n=9 s=0 w=0 e=9 res=2
> > > > > r.univar testrastr s
> > > > > sum: 0.308567902849234
> > > > > IMHO, the sum should always be close to 1, or ?
> > > > I think not, because the Gaussian kernel is a general Gaussian
> > > > function with user-defined sigma = dmax / 4 [0]. The sum would be
> > > > close to 1 only for a normal function (special case of the
> > > > Gaussian function) with sigma determined from the observed
> > > > distances. For the Gaussian kernel, the sum of the output raster
> > > > should increase with higher resolution and constant sigma.
> > > Thanks. I'll have to think about this a bit more when I have the
> > > time to fully understand. I imagine there should be a way to
> > > calculate the multiplier necessary to reach the correct sum
> > I don't think there is something like "the correct sum".
> You are right. Correct is not the right term. However:
> > v.kernel provides an estimate for each output cell, how evenly the
> > input points are distributed around this cell. The definition of
> > "evenly" depends on the kernel function and bandwidth.
> I do not have the exact same understanding of kernel estimation: For me
> it distributes an existing population (defined in GRASS as one per
> point - others provide option to use a population attribute) across a
> space. How it is distributed depends on the kernel function and
> bandwidth. The idea being that for a series of observations in space
> the exact location of that observation is somewhat random and that you
> can thus distribute the actual observations across space.
> If you only have a sample of observations, then you can use a
> multiplier to estimate total observations as long as your sample is
> well distributed. But if you have the total population, then you
> distribute this population in space and the sum across this space
> should correspond to your population.
> Here's how they explain it in the ArcGIS manual (hardly a reference I
> know, but still):
> "Conceptually, a smoothly curved surface is fitted over each point. The
> surface value is highest at the location of the point and diminishes
> with increasing distance from the point, reaching zero at the Search
> radius distance from the point. Only a circular neighborhood is
> possible. The volume under the surface equals the Population field
> value for the point, or 1 if NONE is specified. The density at each
> output raster cell is calculated by adding the values of all the kernel
> surfaces where they overlay the raster cell center."[1]
> Often texts start by saying that the simplest form of the density
> estimation is the histogram. Kernel functions then allow to make this
> smoother, but IMU the surface beneath the curve should stay the same.
> See also the answer by whuber at [2] using the sand analogy. And the
> reference mentioned in the next post [3], where it is said
> "In Figure 4‑43, for each point (7,8,9,12 and 14) we have provided a
> Normal distribution curve with central value (the mean) at the point in
> question and with an average spread (standard deviation) of 2 units. We
> can then add the areas under each of these curves together to obtain a
> (cumulative) curve with two peaks, and then divide this curve by 5 to
> adjust the area under the curve back to 1 giving the lower red curve
> shown. When adjusted in this way the values are often described as
> probability densities, and when extended to two dimensions, the
> resulting surface is described as a probability density surface, rather
> than a density surface. We now have a density value for every position
> along the original line, with smooth transitions between the values,
> which is exactly what we were trying to achieve."
> I guess the question is whether we are speaking about normalized or not
> normalized density ?
When you have a curve or a curved surface, you can normalize to 1. However,
the output raster is a sample of the curved surface at discrete locations
(cell centers). Therefore the sum should increase with higher resolutions,
keeping everything else constant.
Markus M
> Moritz
> [1]
https://pro.arcgis.com/en/pro-app/tool-reference/spatial-analyst/how-kernel-density-works.htm#GUID-3BCBF5CA-CAC7-4547-A3CF-B5E30FDE584E
> [2]
https://gis.stackexchange.com/questions/1553/how-to-interpret-grass-v-kernel-results
> [3]
http://www.spatialanalysisonline.com/HTML/?density__kernels_and_occupancy.htm
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180529/ffafa32d/attachment.html>
