[GRASS-dev] [GRASS GIS] #3525: Removing the behavior of i.maxlik which add the output to input group
GRASS GIS trac at osgeo.org
Thu Nov 1 14:00:04 PDT 2018
  Reporter:  spareeth     |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  8.0.0
 Component:  Imagery      |    Version:  svn-trunk
Resolution:               |   Keywords:  i.maxlik
       CPU:  Unspecified  |   Platform:  All
Comment (by mmetz):
 Replying to [comment:5 veroandreo]:
 > Replying to [comment:3 martinl]:
 > > So you don't need to remove output maps from group in each new run...
 > Good! Thanks for clarification, Martin! I still prefer not to have
 classification results in the group, though ;)
 Assuming that imagery modules accept a group/subgroup as input that is not
 in the current mapset, the output can not be added to the input group if
 it is not in the current mapset.
 The metadata of the output (datasource, description, comments) should in
 any case contain information about how this output has been generated:
 fully qualified input group/subgroup name, fully qualified input signature
 file name if appropriate, and other parameters used by i.maxlik.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3525#comment:6>
