[GRASS-dev] [GRASS GIS] #3525: Removing the behavior of i.maxlik which add the output to input group
GRASS GIS trac at osgeo.org
Fri Nov 2 07:11:43 PDT 2018
  Reporter:  spareeth     |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  8.0.0
 Component:  Imagery      |    Version:  svn-trunk
Resolution:               |   Keywords:  i.maxlik
       CPU:  Unspecified  |   Platform:  All
Comment (by marisn):
 Replying to [comment:6 mmetz]:
 > Replying to [comment:5 veroandreo]:
 > Assuming that imagery modules accept a group/subgroup as input that is
 not in the current mapset, the output can not be added to the input group
 if it is not in the current mapset.
 This is a good argument. Still at the moment only library and i.group has
 been changed to allow reading group contents from other mapsets. See
 r73632 and r73633
 This issue should be viewed together with signature files as those also
 are placed into the group/subgroup.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3525#comment:7>
