[GRASS-dev] GRASS 7.4.2 won't configure on Mac
Michael Barton Michael.Barton at asu.edu
Wed Nov 21 13:21:23 PST 2018
Hi Vaclav,
Thanks for the input. I've been out of town and have not been able to look into this until today.
As far as I can tell, I do not have cpp anywhere in any of the Mac binaries I've done, although I do have a C++ compiler installed. All previous versions compiled and built without this error, and they run fine. So what was changed between 8 October and the release of 7.4.2 that makes configure fail if cpp is not found? Where should I look?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 12, 2018, at 9:04 PM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
Since it's complaining about /lib/cpp,
./configure: line 5164: /lib/cpp: No such file or directory
I would say the problem is not zlib, but missing C++ compiler (at least on my machine, /lib/cpp eventually points to /usr/bin/cpp-5), although I don't know why ./configure would catch that problem earlier since a successful report contains:
  C compiler:                 clang -O2 -Wall -pedantic -Wextra
  C++ compiler:               clang++ -std=c++14 -fexceptions
The checking phase reports only about C compiler, so the difference is perhaps there.
checking for gcc... clang
checking whether the C compiler (clang -O2 -Wall -pedantic -Wextra -s) works... yes
checking whether the C compiler (clang -O2 -Wall -pedantic -Wextra -s) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether clang accepts -g... yes
On Fri, Nov 9, 2018 at 10:58 PM Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
> I could see that it could not find zlib in the configure output. I don't know why, since I DO have zlib in the appropriate place
> MIchael
> On Nov 9, 2018, at 4:21 PM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
> Just scroll to the end of the file.
> ; return 0; }
> configure:5066: checking for socket in -lsocket
> configure:5083:
> /Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang -o conftest
> -g -O2    -I/Applications/GRASS-7.4.2.app/Contents/Resources/include
> -L/Applications/GRASS-7.4.2.app/Contents/Resources/lib conftest.c
> -lsocket   1>&5
> ld: library not found for -lsocket
> clang-4.0: error: linker command failed with exit code 1 (use -v to
> see invocation)
> configure: failed program was:
> #line 5072 "configure"
> #include "confdefs.h"
> /* Override any gcc2 internal prototype to avoid an error.  */
> /* We use char because int might match the return type of a gcc2
>    builtin and then its argument prototype would still apply.  */
> char socket();
> int main() {
> socket()
> ; return 0; }
> configure:5131: checking for location of zlib includes
> configure:5157: checking for zlib.h
> configure:5165: /lib/cpp
> -I/Applications/GRASS-7.4.2.app/Contents/Resources/include conftest.c
> /dev/null 2>conftest.out
> #line 5160 "configure"
> #include <zlib.h>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181121/615ca6b8/attachment.html>
