[GRASS-dev] GRASS 7.4.2 won't configure on Mac
Vaclav Petras
wenzeslaus at gmail.com
Thu Nov 22 06:40:09 PST 2018
On Wed, Nov 21, 2018 at 4:22 PM Michael Barton <Michael.Barton at asu.edu>
wrote:
> As far as I can tell, I do not have cpp anywhere in any of the Mac
> binaries I've done, although I do have a C++ compiler installed. All
> previous versions compiled and built without this error, and they run fine.
> So what was changed between 8 October and the release of 7.4.2 that makes
> configure fail if cpp is not found? Where should I look?
Do you mean a change in GRASS GIS source code or your system configuration
(e.g. updates)? How to decide between them is to configure the last version
of GRASS GIS which worked for you. If you can configure and compile from
scratch that old version but not the new one, you can try a version in
between these two, the go to beginning of this sentence (aka bisect). This
way you find the change in GRASS GIS. In case both the old and the new
version don't configure, the change is in your system.
> On Nov 12, 2018, at 9:04 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Since it's complaining about /lib/cpp,
> ./configure: line 5164: /lib/cpp: No such file or directory
> I would say the problem is not zlib, but missing C++ compiler (at least on
> my machine, /lib/cpp eventually points to /usr/bin/cpp-5), although I don't
> know why ./configure would catch that problem earlier since a successful
> report contains:
> C compiler: clang -O2 -Wall -pedantic -Wextra
> C++ compiler: clang++ -std=c++14 -fexceptions
> The checking phase reports only about C compiler, so the difference is
> perhaps there.
> checking for gcc... clang
> checking whether the C compiler (clang -O2 -Wall -pedantic -Wextra -s)
> works... yes
> checking whether the C compiler (clang -O2 -Wall -pedantic -Wextra -s) is
> a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether clang accepts -g... yes
> On Fri, Nov 9, 2018 at 10:58 PM Michael Barton <Michael.Barton at asu.edu>
> wrote:
> > I could see that it could not find zlib in the configure output. I don't
> know why, since I DO have zlib in the appropriate place
> > MIchael
> > On Nov 9, 2018, at 4:21 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > Just scroll to the end of the file.
> > ; return 0; }
> > configure:5066: checking for socket in -lsocket
> > configure:5083:
> > /Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang -o conftest
> > -g -O2 -I/Applications/GRASS-7.4.2.app/Contents/Resources/include
> > -L/Applications/GRASS-7.4.2.app/Contents/Resources/lib conftest.c
> > -lsocket 1>&5
> > ld: library not found for -lsocket
> > clang-4.0: error: linker command failed with exit code 1 (use -v to
> > see invocation)
> > configure: failed program was:
> > #line 5072 "configure"
> > #include "confdefs.h"
> > /* Override any gcc2 internal prototype to avoid an error. */
> > /* We use char because int might match the return type of a gcc2
> > builtin and then its argument prototype would still apply. */
> > char socket();
> > int main() {
> > socket()
> > ; return 0; }
> > configure:5131: checking for location of zlib includes
> > configure:5157: checking for zlib.h
> > configure:5165: /lib/cpp
> > -I/Applications/GRASS-7.4.2.app/Contents/Resources/include conftest.c
> > /dev/null 2>conftest.out
> > #line 5160 "configure"
> > #include <zlib.h>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181122/0e12788a/attachment-0001.html>
