[GRASS-dev] [GRASS-SVN] r73692 - grass/trunk/lib/init
Vaclav Petras wenzeslaus at gmail.com
Sat Nov 24 18:58:39 PST 2018
On Sat, Nov 24, 2018 at 5:54 AM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Thu, Nov 22, 2018 at 11:33 PM Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > That's all correct. There would have to be more to make it the same
> procedure as in grass.py, but eventually we need to do that.
> > What I meant to add it to grass.script.setup module where we should
> eventually put all the functions needed to setup a proper GRASS session (or
> in some other module, but setup seems to be something good enough for now
> and moving things around while keeping the API is easy in Python).
> ok, the db cleanup is now (r73704) a function in grass.script.setup
Great! Thanks. I tried to clean grass.py as much as possible, so I hope
it's possible to make changes there.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181124/727886ad/attachment.html>
