[GRASS-dev] [release] planning GRASS 7.4.2
Moritz Lennert mlennert at club.worldonline.be
Wed Nov 28 06:08:13 PST 2018
On 28/11/18 14:54, Jürgen E. Fischer wrote:
> Hi Martin,
> On Wed, 28. Nov 2018 at 14:39:16 +0100, Martin Landa wrote:
>> 1) update GRASS package (as current) to OSGeo4W when released
>> + a new GRASS version available in OSGeo4W when released
>>   - we don't care about broken QGIS GRASS plugin
>> 2) publish GRASS release in OSGeo4W as test package and change to
>> current when new QGIS point release
>> + QGIS GRASS plugin will be not broken
>> - new GRASS version available when QGIS point release published
>> +/- there is still possibility to install new GRASS version from Expr area
>> Any comments? I would vote for 2). In this case Juergen could you
>> change test -> curr in GRASS setup.hint when pushing new QGIS point
>> release to OSGeo4W or let me/us know to do it? Would be nice to
>> collaborate more closely to avoid broken QGIS-GRASS interfaces.
> Last time the GRASS release was shortly before the QGIS release and fell in
> smoothly - this time it's shortly after.  The QGIS release echedule is set long
> upfront.
> Not putting the patch level into the GRASS library names (and keeping an eye on
> the ABI - but I suppose the library interfaces only change rarely anyway - and
> if so not on point releases), would be a third option.  IIRC there's also still
> a safety check to remove in the GRASS libs to make this possible.  Then GRASS
> point releases wouldn't need a QGIS rebuild at all.
This sounds like the way to go for me. AFAIK, there shouldn't be ABI
changes between point releases.
Moritz
