[GRASS-dev] [GRASS GIS] #3670: Ubuntu 16.04 install wx python issue
trac at osgeo.org
Mon Oct 1 15:36:44 PDT 2018
Reporter: khayley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Installation | Version: 7.4.1
Keywords: | CPU: Unspecified
Platform: Linux |
When I run through the directions here:
https://grass.osgeo.org/download/software/linux/
Using the unstable ppa
Then try to start grass in the terminal I get an error “wxGUI requires
wxPython. No module named wx”
Python-wxgtk3.0 is installed on the machine so not sure what the issue may
be.
If I try start grass with the -text command then I get an error “Unable to
start Grass GIS”
I tried installing the grass-daily build to see if I had better success,
but no luck
Ticket URL: <https://trac.osgeo.org/grass/ticket/3670>
