[GRASS-dev] [GRASS GIS] #3670: Ubuntu 16.04 install wx python issue
trac at osgeo.org
Sun Oct 14 17:04:03 PDT 2018
Reporter: khayley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Installation | Version: 7.4.1
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by khayley):
Hi I solved the issue I was having with the GRASS (and QGIS) install on
Ubuntu.
I had Anaconda python installed for data analysis, so there were issues
with dependencies between the root python install and the Anaconda Python.
this Blog helped me figure it out
https://kangarooha.wordpress.com/2015/06/16/fix-the-error-couldnt-load-
pyqt4-python-support-will-be-disabled-while-using-continuums-anaconda/
and
https://stackoverflow.com/questions/20364700/using-two-different-python-
distributions
setting up the Anaconda python as an alias did the trick, Grass and QGIS
(provided by ubuntugis) installed fine and are working. Spyder that I use
for data analysis still finds the Anaconda python core by default so I
have not lost anything in the process.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3670#comment:1>
