[GRASS-dev] [GRASS GIS] #3621: Cannot create map frame in cartographic composer
GRASS GIS trac at osgeo.org
Tue Oct 2 18:39:12 PDT 2018
  Reporter:  cmbarton     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  critical     |  Milestone:  7.4.2
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  map frame, cartographic composer
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by annakrat):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Replying to [comment:20 cmbarton]:
 > This is all working now. I ran across another bug in 7.4 only that kept
 the preview from working but managed to fix it (r73482). I am closing.
 You should check in 7.6 and trunk, it's likely it needs to be there
 changed too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:21>
