[GRASS-dev] [GRASS GIS] #3621: Cannot create map frame in cartographic composer
trac at osgeo.org
Tue Oct 2 18:41:28 PDT 2018
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 7.4.2
Component: wxGUI | Version: unspecified
Resolution: fixed | Keywords: map frame, cartographic composer
CPU: Unspecified | Platform: Unspecified
Changes (by cmbarton):
* status: reopened => closed
* resolution: => fixed
Comment:
I did. This was only a problem in 7.4. I ended up using the code from 7.6
to fix 7.4 (message_ becomes just _ in line 388,
../gui/wxpython/psmap/frame.py)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:22>
