[GRASS-dev] v.in.ogr and v.import do not import all features in gpkg file
Veronica Andreo
veroandreo at gmail.com
Tue Oct 9 05:11:10 PDT 2018
A follow up:
If I convert the gpkg to shapefile and import into GRASS, then all points
are imported:
v.import input=central.shp layer=central output=central --overwrite
Check if OGR layer <central> contains polygons...
Creating attribute table for layer <central>...
Importing 30 features (OGR layer <central>)...
Building topology for vector map <central at testing>...
Registering primitives...
Input <central.shp> successfully imported without reprojection
v.db.select -c central | wc -l
30
What could be the problem with gpkg and how to test further??
El lun., 8 oct. 2018 a las 21:24, Veronica Andreo (<veroandreo at gmail.com>)
escribió:
> Hello devs
> I found a quite striking issue when importing a simple vector file. It is
> a gpkg file with 30 points and only one field as attribute. When I import
> it into GRASS, either with v.in.ogr or v.import, I only get 28 points
> imported. No idea why. Meanwhile, ogrinfo -al reports 30 points, same as
> QGIS
> v.in.ogr input=central.gpkg layer=central output=central
> WARNING: Vector map <central> already exists and will be overwritten
> Importing 28 features (OGR layer <central>)...
> 28
> I attach the file.
> Thanks much in advance
> Vero
> ps: I use trunk r73492
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181009/88754df0/attachment.html>
