[GRASS-dev] OSGeo4W-winGRASS 7.7 with new gdal, geos, proj4
Martin Landa landa.martin at gmail.com
Thu Oct 18 04:59:34 PDT 2018
čt 18. 10. 2018 v 13:58 odesílatel Markus Metz
<markus.metz.giswork at gmail.com> napsal:
> As long as the old PROJ 4 API is still supported by PROJ 5, G74 can use PROJ 5, no need to disable G74 or downgrade PROJ. G74 would simply not make use of new features and the new API in PROJ5.
ah, you are right. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
