[GRASS-dev] OSGeo4W-winGRASS 7.7 with new gdal, geos, proj4
Markus Metz
markus.metz.giswork at gmail.com
Thu Oct 18 04:58:04 PDT 2018
On Thu, Oct 18, 2018 at 1:43 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> st 17. 10. 2018 v 17:54 odesÃlatel Helmut Kudrnovsky <hellik at web.de>
napsal:
> > - PROJ 5.2.0 (from 4.9.3; plus datumgrids)
> > - GEOS 3.7.0 (from 3.6.2)
> > - SpatiaLite 4.3.0a (from 4.3.0; also with lwgeom from postgis 2.5)
> > - GDAL 2.3.2 (from 2.2.4; including updated/rebuilt dependencies ogdi &
> > openfyba)
> I have updated packages (except of PROJ) in building/packaging
> environment. Next daily builds should be built against new deps.
> Please test, at least G74 since we are close release.
> About PROJ4/5. My suggestion:
> 1) disable G74 daily builds and update to PROJ 5 (for G74 releases
> PROJ would need to be downgraded to PROJ 4)
As long as the old PROJ 4 API is still supported by PROJ 5, G74 can use
PROJ 5, no need to disable G74 or downgrade PROJ. G74 would simply not make
use of new features and the new API in PROJ5.
Markus M
> 2) invest rather time/energy to set up a new building/packaging
> environment for G77 using Python3 and wxPython4
> Any comments? Thanks, Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181018/68b18fde/attachment.html>
