[GRASS-dev] [GRASS GIS] #3690: r.stats.quantile crashing with data linked through r.external
trac at osgeo.org
Wed Oct 31 05:06:01 PDT 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Raster | Version: svn-
| releasebranch74
Keywords: r.external, r.stats.quantile | CPU: Unspecified
Platform: Unspecified |
We discovered that r.stats.quantile crashes with data linked through
r.external (when importing the same data sets with r.in.gdal it works
fine).
It seems that a corruption occurs with GDAL?
GRASS 7.4.3svn (utm30N): > r.external input="covermap.tif" band=1
output=tmp15409185587112 --overwrite -o
Reading band 1 of 1...
r.external komplett. Link to raster map <tmp15409185587112> created.
GRASS 7.4.3svn (utm30N): > r.external input="basemap.tif" band=1
output=tmp15409185587113 --overwrite -oÜ
r.external komplett. Link to raster map <tmp15409185587113> created.
GRASS 7.4.3svn (utm30N): > r.stats.quantile -p base="tmp15409185587112"
cover="tmp15409185587113" bins="2000"
Computing histograms
100%
Speicherzugriffsfehler (Speicherabzug geschrieben)
... i.e. Core dump.
Debugging:
GRASS 7.4.3svn (utm30N): > gdb r.stats.quantile
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.5) 7.11.1
(gdb) r -p base="tmp15409185587112" cover="tmp15409185587113" bins="2000"
Starting program: /home/user/src/grass-7.4.svn/dist.x86_64-pc-linux-
gnu/bin/r.stats.quantile -p base="tmp15409185587112"
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
100%
27%
Program received signal SIGSEGV, Segmentation fault.
0x0000000000401fa0 in get_slot_counts (basefile=0, coverfile=1) at
main.c:161
161 bc->slots[i]++;
(gdb) bt
#0 0x0000000000401fa0 in get_slot_counts (basefile=0, coverfile=1) at
main.c:161
#1 0x0000000000403c89 in main (argc=5, argv=0x7fffffffd878) at main.c:642
(gdb) bt full
main.c:161
basebuf = 0x6c5760
coverbuf = 0x6c6eb0
bc = 0x6f3ab0
row = 467
col = 1305
i = 0
allnull = 0
module = 0x7ffff7ba0ea8 <state+40>
opt = {quant = 0x640ec0, perc = 0x641000, slots = 0x641140,
basemap = 0x7ffff7ba0f08 <state+136>, covermap = 0x640d80, output =
0x641280, file = 0x641440, fs = 0x641640}
flag = {r = 0x7ffff7ba0ed8 <state+88>, p = 0x6426a0, t = 0x6426d0}
basemap = 0x61edb0 "tmp15409185587112"
covermap = 0x61ee80 "tmp15409185587113"
outputs = 0x0
fs = 0x7fffffffd72f "@"
reclass = 0
print = 1
cover_fd = 1
base_fd = 0
range = {min = 1, max = 1061, first_time = 0}
fprange = {min = 7.0767250061034996, max = 9.9984693527221999,
first_time = 0}
i = 1
(gdb)
Looking at memory allocation and G_free() usage, I see that not all is
freed:
cd r.stats.quantile/
grep 'G_calloc\|G_free' main.c | grep bc
bc->slots = G_calloc(bc->num_slots, sizeof(unsigned int));
bc->bins = G_calloc(num_quants, sizeof(struct bin));
bc->slot_bins = G_calloc(bc->num_slots, sizeof(unsigned char));
G_free(bc->slots);
bc->values = G_calloc(num_values, sizeof(DCELL));
G_free(bc->slot_bins);
but I am not sure if that is related.
We can make the two GeoTIFF files offlist available.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690>
