[GRASS-dev] [GRASS-SVN] r73627 - grass/trunk/raster/r.stream.extract
Huidae Cho
grass4u at gmail.com
Wed Oct 31 10:56:10 PDT 2018
Markus,
What is the best way to test my translation? I know we have the transifex
merge script, but that will overwrite the SVN version of the files, which
can be accidentally checked in.
Regards,
Huidae
On Wed, Oct 31, 2018 at 1:38 PM Markus Neteler <neteler at osgeo.org> wrote:
> Please wait.
> First also the .po files need that update add I have done last time as
> well.
> Then no translation will be broken.
> Markus
> Huidae Cho <grass4u at gmail.com> schrieb am Mi., 31. Okt. 2018, 15:06:
>> Hmm... I never thought about backporting these changes... So just G76
>> should be fine then?
>> Huidae /hidɛ/
>> On Wed, Oct 31, 2018 at 5:29 AM Martin Landa <landa.martin at gmail.com>
>> wrote:
>>> Hi,
>>> st 31. 10. 2018 v 10:05 odesílatel Maris Nartiss <maris.gis at gmail.com>
>>> napsal:
>>> > ... and by doing so marking all translated strings as untranslated.
>>> > This exactly is a type of change that should NOT be backported – the
>>> > meaning of this string can be understood also when it is misspelled
>>> > and backporting would thus harm translations.
>>> it can be right for G74 release branch but for for G76 where typos
>>> should be simply fixed. Ma
>>> > > > --- grass/trunk/raster/r.stream.extract/cseg.c 2018-10-30
>>> 21:00:49 UTC (rev 73626)
>>> > > > +++ grass/trunk/raster/r.stream.extract/cseg.c 2018-10-31
>>> 01:54:09 UTC (rev 73627)
>>> > > > @@ -83,7 +83,7 @@
>>> > > > int cseg_get(CSEG *cseg, CELL *value, GW_LARGE_INT row,
>>> GW_LARGE_INT col)
>>> > > > if (Segment_get(&(cseg->seg), value, row, col) < 0) {
>>> > > > - G_warning(_("Unabel to read segment file"));
>>> > > > + G_warning(_("Unable to read segment file"));
>>> > > > return -1;
>>> > > > return 0;
>>> > > > _______________________________________________
>>> > > > grass-commit mailing list
>>> > > > grass-commit at lists.osgeo.org
>>> > > > https://lists.osgeo.org/mailman/listinfo/grass-commit
>>> > > Martin Landa
>>> > > http://geo.fsv.cvut.cz/gwiki/Landa
>>> > > http://gismentors.cz/mentors/landa
>>> > > grass-dev mailing list
>>> > > grass-dev at lists.osgeo.org
>>> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
>>> Martin Landa
>> Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
>> Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181031/423afd1d/attachment-0001.html>
