[GRASS-dev] [GRASS-SVN] r73627 - grass/trunk/raster/r.stream.extract
Markus Neteler
neteler at osgeo.org
Wed Oct 31 10:38:04 PDT 2018
Please wait.
First also the .po files need that update add I have done last time as well.
Then no translation will be broken.
Markus
Huidae Cho <grass4u at gmail.com> schrieb am Mi., 31. Okt. 2018, 15:06:
> Hmm... I never thought about backporting these changes... So just G76
> should be fine then?
> Huidae /hidɛ/
> On Wed, Oct 31, 2018 at 5:29 AM Martin Landa <landa.martin at gmail.com>
> wrote:
>> Hi,
>> st 31. 10. 2018 v 10:05 odesílatel Maris Nartiss <maris.gis at gmail.com>
>> napsal:
>> > ... and by doing so marking all translated strings as untranslated.
>> > This exactly is a type of change that should NOT be backported – the
>> > meaning of this string can be understood also when it is misspelled
>> > and backporting would thus harm translations.
>> it can be right for G74 release branch but for for G76 where typos
>> should be simply fixed. Ma
>> > > > --- grass/trunk/raster/r.stream.extract/cseg.c 2018-10-30 21:00:49
>> UTC (rev 73626)
>> > > > +++ grass/trunk/raster/r.stream.extract/cseg.c 2018-10-31 01:54:09
>> UTC (rev 73627)
>> > > > @@ -83,7 +83,7 @@
>> > > > int cseg_get(CSEG *cseg, CELL *value, GW_LARGE_INT row,
>> GW_LARGE_INT col)
>> > > > if (Segment_get(&(cseg->seg), value, row, col) < 0) {
>> > > > - G_warning(_("Unabel to read segment file"));
>> > > > + G_warning(_("Unable to read segment file"));
>> > > > return -1;
>> > > > return 0;
>> > > > _______________________________________________
>> > > > grass-commit mailing list
>> > > > grass-commit at lists.osgeo.org
>> > > > https://lists.osgeo.org/mailman/listinfo/grass-commit
>> > > Martin Landa
>> > > http://geo.fsv.cvut.cz/gwiki/Landa
>> > > http://gismentors.cz/mentors/landa
>> > > grass-dev mailing list
>> > > grass-dev at lists.osgeo.org
>> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
>> Martin Landa
> Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
> Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181031/6281dcce/attachment.html>
