[GRASS-dev] [GRASS GIS] #3690: r.stats.quantile crashing with data linked through r.external
trac at osgeo.org
Wed Oct 31 15:05:06 PDT 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Raster | Version: svn-releasebranch74
Resolution: | Keywords: r.external, r.stats.quantile
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:1 mmetz]:
> The above commands do not work for me because basemap and covermap are
swapped
ops, maybe I flipped that while anonymising the data using the output from
the QGIS Processing log file.
> and the base map must be CELL type.
Would it be possible to add a test for that?
> These commands
> r.external input=covermap.tif band=1 output=covermap_ext
> r.external input=basemap.tif band=1 output=basemap_ext
> r.stats.quantile -p base=basemap_ext cover=covermap_ext bins=2000
> work for me without segfault and valgrind does not find any memory
violations.
> I am using GDAL 2.3.2.
The machine causing problems is Linux Mint (Ubuntu). The versions I don't
have right now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:2>
