[GRASS-dev] Fwd: [QGIS Application - Bug report #19733] v.rast.stats is broken due to parsing error of double underscore in column names
Markus Metz
markus.metz.giswork at gmail.com
Sat Sep 1 10:14:40 PDT 2018
On Sat, Sep 1, 2018 at 6:07 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Sat, Sep 1, 2018 at 7:58 AM Markus Neteler <neteler at osgeo.org> wrote:
> > Hi devs,
> > does anyone have an idea how to fix this issue in QGIS processing?
> this is a GDAL error message also happening in GRASS directly:
> > v.out.ogr --overwrite -s -e input=tmp15356101025715
output="/tmp/processing5113522d9c174e7bb445f24ef38c5f5a/135e78c4ae1d430da568b502506b4ab0"
format=ESRI_Shapefile output_layer=output
> > ERROR 6: Failed to add field named 's_third_quartile'
> > ERROR 6: Failed to add field named 's_percentile_2'
> the underscores are not the problem because exporting columns like
's_t_q' and 's_p_2' works. The field names are too long for dbf (max 10
characters). The solution would be to allow that "the field may be created
in a slightly different form depending on the limitations of the format
driver" [0] in v.out.ogr. The ERROR 6 would then change to e.g.
> Warning 6: Normalized/laundered field name: 's_third_quartile' to
's_third_qu'
another solution would be that QGIS uses GeoPackage instead of ESRI
Shapefile as vector data exchange format
> Markus M
> [0] https://gdal.org/ogr__api_8h.html#aab585ef1166c61c4819f7fd46ee4a275
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180901/fb286883/attachment.html>
