[GRASS-dev] Fwd: [QGIS Application - Bug report #19733] v.rast.stats is broken due to parsing error of double underscore in column names
Markus Neteler neteler at osgeo.org
Sat Sep 1 11:41:17 PDT 2018
On Sat, Sep 1, 2018 at 7:14 PM Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Sat, Sep 1, 2018 at 6:07 PM Markus Metz <markus.metz.giswork at gmail.com> wrote:
> > this is a GDAL error message also happening in GRASS directly:
> > > v.out.ogr --overwrite -s -e input=tmp15356101025715 output="/tmp/processing5113522d9c174e7bb445f24ef38c5f5a/135e78c4ae1d430da568b502506b4ab0" format=ESRI_Shapefile output_layer=output
> > > ERROR 6: Failed to add field named 's_third_quartile'
> > > ERROR 6: Failed to add field named 's_percentile_2'
> > the underscores are not the problem because exporting columns like 's_t_q' and 's_p_2' works. The field names are too long for dbf (max 10 characters).
Oh, in fact I didn't try with SHP file format (meanwhile I tend to
forget about it :-)
> > The solution would be to allow that "the field may be created in a slightly different form depending on the limitations of the format driver" [0] in v.out.ogr. The ERROR 6 would then change to e.g.
> > Warning 6: Normalized/laundered field name: 's_third_quartile' to 's_third_qu'
> another solution would be that QGIS uses GeoPackage instead of ESRI Shapefile as vector data exchange format
I have proposed the latter in the now updated QGIS ticket:
https://issues.qgis.org/issues/19733
Thanks for your analysis!
markusN
