[GRASS-dev] [GRASS GIS] #3462: Allow setting environment variables in grass startup script
GRASS GIS trac at osgeo.org
Mon Sep 3 14:23:20 PDT 2018
  Reporter:  mankoff     |      Owner:  martinl
      Type:  defect      |     Status:  closed
  Priority:  major       |  Milestone:  7.6.0
 Component:  Startup     |    Version:  7.2.2
Resolution:  fixed       |   Keywords:  init grass.py env D_LIBRARY_PATH
       CPU:              |  bashrc
  Unspecified            |   Platform:  MacOSX
Changes (by wenzeslaus):
 * keywords:   => init grass.py env D_LIBRARY_PATH bashrc
 * status:  reopened => closed
 * resolution:   => fixed
 * milestone:  7.2.4 => 7.6.0
Comment:
 This was already fixed and reopened for backport in comment:23. This may
 not be a change which is appropriate to backport. At this point, it will
 just be in 7.6. Changing milestone. Closing as fixed.
 For the record, GRASS GIS itself doesn't use `GRASS_LD_LIBRARY_PATH` at
 this point.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:27>
